14b turbo question
kelvinb
726
3
May 7, 2004
Lincoln, Nebraska
I just bought a 14b for 50 bucks with alittle shaft play (up and down play) anyways i took the exhaust housing off because i heard something rattling, and right behind the exhaust turbine is a piece that is loose. does the exhaust housing hold it down or is this bad?
kelvinb said:
...a 14b ...alittle shaft play (up and down play) ...right behind the exhaust turbine is a piece that is loose. .../QUOTE]
1. slight radial end play is normal (~2mm)
2. axial endplay is not good
3. metal cup behind turbine wheel is loose until housing is attached (unless carbon build up has it solidified in place.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
