14B Question?
Slider925
66
Apr 2, 2005
Lemoyne, Pennsylvania
Is the 14B oil cooled, water cooled, or both? I was checking out the Bullseye T04B V-Trim and it has the option of water cooled, so I wasn't sure if the 14B was water cooled. Thanks.
Hello,
I see your from Lemoyne, Pennsylvania. I'm from Mechanicsburg, Pennsylvania. My name is John, and I drive a black 99' gst. Maybe I'll see you around, Cause I'm ALWAYs over by the KFC and Burger King in lemoyne, because my friend lives over there. Anyways, I did a search and found that it is both. You might also want to check this 1st Gen. t0b vtrim install post. http://www.dsmtuners.com/forums/showthread.php?t=177721&highlight=14b+cooled Good luck!
Jahjahpoet said:
Hello,
Thanks for the info and I will keep an eye out for you. I have a green 91 GSX.
The Turbo is water (coolant) cooled. While the oil may provide some cooling capibility it's main function is to lubricate the bearings in the housing. The oil does tend to pick up a lot of heat though because the turbo is hot.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
