GSLENK
- 1,416
- 54
- May 25, 2011
DC,
Maryland
My o2 housing wastegate flange is warped. I used a feeler gauge and it is right between .005" and .006" only on one side, the opposing and orthogonal sides seal fine. I first bought a set of multi layer SS gaskets with fire rings. There is still that gap when torqued down (also the gap is on the wastegate fire ring, which lead me to believe the flange is warped).
I can file it down a bit to get it to about .004-.003 gap. Anything else I can use to finish it off? Ultra copper RTV? Copper spray?
I swear I read something about a maximum gap for each, any ideas?
Should I even use gaskets? or just try to seal it with rtv?
. if not... I need an MVS.
