warped head?
TalonFULLtune
107
7
Jan 15, 2013
three churches, West Virginia
I blew headgaskert after blowing off the oil filter. Put everything back togather with a mls headgasket but its seeping coolant under the cam gears. Is this warped? And can i mill the head and how much? thanks for all the help
No the head and block havent been decked as far as i can tell. I only have had this car for 3 months not sure of its history.
The head and block need to be resurfaced specifically for an MLS head gasket in order for it to properly seal. I would pull the head and have it inspected by a machinist. They will be able to tell if the head is warped, cracked, etc. If the head checks out, I would get a basic resurface done and install with a Mitsubishi or Felpro composite gasket. Also be sure to follow the proper torque sequence when installing.
As WES said, in order to have a MLS HG properly seal you need both the block and head to be surfaced. A composite head gasket will allow the seal to work well after having just the head surfaced as long as your block is still in good shape. It takes a lot to warp the block, but its pretty easy to warp the head with a blown HG
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
