Project 9s: Street Driven 98 Eclipse Auto
2G Eclipse with a slushbox, and AWD converted.
The popping you hear at the end is because my muffler left the chat:rolleyes:, so you can just hear the loud ass pops and bangs during decel. The video doesn't do it justice man, it literally sounded like gunshots and me doing this in the very wee hours of the morning might have elicited a 5-0 response ROFL ROFL:p. Gonna lay low for awhile. I am slowly gonna crank her up though as I need the car to be ready for the 1 and only track visit I will make with it this year. So, not a lot of street runs till I get the muffler on there. It's way too loud right now to drive on the street. I did swap in brand new plugs. The car is still puking oil from the catchcan, maybe about a cup full after every run like this but I will just manage it until I decide what to do with the bottom end this off season if I don't send it to heaven first. :sneaky:
if youre building a 2L, go long rod I beam, thats what i will be doing at some point
I am still very undecided what I will do but that is one of the options.
Yeah...still on the fence on what I am going to do. 2.0L is the quickest ticket but then I have to add a bottle to it.
Broke some shit over the weekend.
I guess it's not supposed to look like this?
Radiator took couple bullet hits too and was destroyed. Need a new one.
Repositioned my charge pipe properly at a better angle so it does not do this. I think I will get it beaded for a better seal for that 40psi+.
With that been said, the car ran a best in the 1/8th with the car not even being on power the full 1/8th because of the coupler popping off. :hellyeah: :hellyeah: I am going to change the tune a little on spool up so it can stop pushing through the brakes. This is the reason the start of the run is so bad. It just pushed through the brakes. :coy:
A couple photos from this past weekend before I took the boys to get some Burger King! :hellyeah::hellyeah::hellyeah:
Chilling with big bro who is about to go to to the track very soon! I can't believe it's been almost a year since I took that other car to the track.
New radiator is in, I actually bought a knock off AFCO from AlloyWorks. We will see how well it works out. Visually, I could not tell the difference between it and the old radiator. The 4 mounting bosses had a different thread and pitch. That was all. This unit is also advertised as a 3-row, unlike the OG unit. The price delta was too huge ($109 v/s $500) for me not to try it out. I went with the medium SPAL fan #30101522 that I also used in my old GVR4 project and had great success with. My old radiator had 16AN fittings welded onto it and I hated that for this very reason. I would need to have someone weld the damn fittings every time. So, I just converted this to a hose setup using these very nifty AN to hose fittings. I just need to add some water in there and will be back in business. Going to use this chance to properly mount my 2nd oil catch can as well.
I probably shouldn't have said a damn thing. I went to mount the FMIC and apparently this new radiator is about 1/2" to 1" thicker so this moves my FMIC forward about 1/2" and it will not bolt onto the pre-made mounting tabs :mad: :mad: :mad: :mad: :mad: so I will need to find another solution by using some kind of bracketry. I wish I could weld! 1/2" off.
Definitely. I have been procrastinating for a very long time. I did rig up some bracketry and get the FMIC well mounted....just waiting on a new coupler. So many little adjustments I had to make but this is to ensure I am not popping off another coupler.
Final update for the Eclipse for 2026. I have decided to go ahead and pull the engine and not risk popping it. The crankcase pressure and blowby has just gotten worse. Time for that 2.0L that it desperately needs. Killer time though going uphill on my 430 treadwear all seasons, unprepped street! No N2O on this car either. Gonna miss the 2.3 but I need the RPM. :rocks::rocks::rocks::rocks:
So boys, what should I build?
2.0L?
2.0L long rod?
2.1L?
2.2L?
The 2.0Ls seem straight forward as I have built tons of those, and they may be cheaper. I have a 2.0L block in the garage 0.50mm over bore and a cut 6-bolt crank in my garage I had machined pre Covid. I would like to use these? I am not sure about the condition of my current 2.0L block, but it should be in decent shape...maybe get some light machine work. I will not know until I have looked at it. Plan is for the car to be able to hold 1000whp at full kill. I may never get there but I like making things really solid in case of an oopsie.
I guess I could also keep it 2.3, just make it stronger but this will limit me to 1/8th mph stuff. Not terrible but I like the 1320. With my 245/45/17 tire combo, 9,000rpm is 144/145mph in this car in 3rd gear so if I kept it 1/8th mile car, I would be fine.
2.0L?
2.0L long rod?
2.1L?
2.2L?
Based on my on my own experience I run 2.0 150mm rods 10.1 that’s been the same setup for a while. Why … well a lot of these parts can be purchased off the shelf nothing custom were it would cost more money. If you need more torque to
Stall it just spray it.
2.0L?
2.0L long rod?
2.1L?
2.2L?
Im also in the same boat trying to decide on a motor build. Ive been using your build thread to justify using my built 2.3L (150mm ibeam/ Wiseco HD pistons motor), so every time you mention going 2.0L I second guess using my 2.3 LOL(ill add, everything on my end is hypothetical as i need to spend energy getting my car running vs going back and forth with engines)
I like the 2.3 in theory, to "get away" with not using a bottle ( one less thing to worry about / manage) but i dont want to limit rpms. in my 2.4 evo i always felt like i wanted more RPM on the big end... I also think with where i see my build going, it will most likely doing 1/8th stuff where the 2.3 may work "better" in a sense?
ive got a set of 156mm ibeams laying around that ive wanted to do a build with, but not sure what configuration would work with them.. A 2.2L sounds fun, but ive never built one and would need to do some more homework.
building a 2.0 and adding a bottle seems to be the simplest solution, im just scared to put a bottle on it ROFL
@gregs4g63 I made a little video here. You can see I lifted right at around 144/145mph. That was at 9,000rpm per my log. I have 245/45/17 tires which is about 25.7"??? Not really good on a 2.3L. So, if you never plan to go faster than that, it may work out. The 2.3L is awesome tho. You can see in these videos how quickly I can get it on the chip. I am only launching at about 10psi and 4100rpm. That is conservative as I am on street tires. I wish I could keep it 2.3L but then I would have to be content keeping my speed lower than 140mph. Decisions.
I totally agree with your assessment here.
There’s nothing to be scared about nitrous
Also, you have to take for account how high you’re going to rev this motor. If you’re going to add a large turbo, you’re going to rev it out ill you might be best to get a 2.0 but that’s just me
It's approaching the end of 2026, and unfortunately, I will not meet my set goal for the year which was to take my 2G to the track to make a pass....any pass. The main reasom really is I no longer have a truck. Unfortunately, my car has no overdrive either so I couldn't drive it to the track either and it is more than capable to do so. It is a street car. I intend to remedy those two "problems" for 2027. In the meanwhile, I was able to dial in my car pretty good considering the start of the year. I am confident in saying that at the track, one of these passes would have been a 9.99-10.00 (just going by how my Dragy runs compared to the track) but we will see next year. My best 1/8th mile hits on the street below on all seasons tires. Excited for next year. :hellyeah: Engine should be out in a few days so I can do those maintenance and upgrades of the bottom end.
