ECMlink Wot log advice ecmlink sd
I took a quick look at it and I don't see anything that sticks out as being way off. Fuel trims appear good. on your good pull to 5000+ rpm at WOT looks just a bit rich but that is better than being to lean and melting parts.
I will try to look it over again. I scroll over them when I am not busy at work ;)
Thanks. I just feel like it shouldn't be so lean when I'm starting the pull.
It is. And it shouldn't be. WBfactor is anywhere from 5-10% from 2000-3500rpms. You can add fuel to those ve cells. It's going to put the ve around 100 though. Alternatively, you could use the fuel sliders, that way it won't affect any of the neighboring cells when cruising. These are low impedance injectors i'm assuming? How does it feel during idle/cruise?
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
