ECMlink WOT Log
Finally I did tuned my WOT.Here is the log. What is the best option in my case to get the most of my car?! Since i don't have a knock should i run a bit leaner afr's or add more timing? I don't want to raise the boost (My current boost is 23psi) due stock headgasket (arp's studs). I want to get good power before knock,and then ill be tuning with meth injection.... Any options are welcome....
Two logs:
one with stock timing map,another one with 4deg added
