snowborder714
Moderator
- 16,188
- 466
- Oct 15, 2006
Mechanicsburg,
Pennsylvania
First you need to go through the MAF Comp sliders and make the adjustments like I mentioned above.
Then once you have the two lines on top of each other, go into the OpenLoopMaxOct DA table and adjust the target AFR based on load and RPM. As long as the two lines are on top of each other, the car will target whatever you put in the DA table.
