ECMlink Need some help with wot log.
Why are you running a stock evo 8 timing map? It is much less aggressive than either a 1g or 2g stock map. That is probably why it is pulling timing.
If you want a happy medium, start with a 2g map and work from there.
The order of aggressive timing maps from most aggressive to least aggressive is:
1g > 2g > Evo 8
If you are hitting 9s in the AFRs, then you should be adding timing anyway.
Hope this helps!
