Need help with my log
Honda hunter 1
83
Nov 4, 2009
magog, Vermont
My setup
6 bolt motor
880 pte injectors
50 trim turbonectic
I,m looking for advice on tuning my car.I have some knock issues,I am running 91 octane for now .Do my fuel trims look all right?
I didn't get a chance to look at your log because I am at work but when I first got link I was getting alot of knock, a guy told me to change it to where knock only comes in after 50 percent throttle. helped out alot, alot of the time before then its just engine noise. also when I did my head last month noticed my sensor was bad spent 50 dollars on a new one haven't had anything over .4 percent knock since. I hope that will help in some way, also if you haven't looked at the videos on ecm link check them out if you know your sensor is good and your only getting knock in wot you might have to retard your timing a bit in your timing tables.
