turbosax2
Moderator
- 4,482
- 673
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
I'm not sure where boostin2high put it. There is at least 1 wire you have to lengthen for sure. Actually, I just lengthened all of the wires before I realized I probably didn't have to because they were long enough already.
Are you trying to avoid lengthening any wires? If you don't mind doing some rewiring, you can probably put the whole harness underneath the intake manifold fairly easily. I would run the injector wires in the gaps in the im and lengthen the wires from the coil pack, tps, and mdp to go underneath the im.
