Wide band O2 will not log on dsmlink
kimper007
Oct 14, 2011
Duluth, Minnesota
I can't seem to get my NGK AFX to log any numbers on my Dsm link other then 13.6. The gauge itself reads fine but when I watching Dsm link it says 13.6 and doesn't move. I looked at the connections at the ECU and everything looks good so I am thinking set up. Is there something I am missing here? Can someone walk me through the setup steps on how to set this up.
I have an aem wide band and 1g also. Ecm link makes you simulate a narrow signal from a wideband.
AEM is probably different than yours. But, I know you need a signal coming into pin 4 on ecu. Ground will either need an ecu ground or chassis. Depending on your guage. AEM didn't require ecu ground.
Mine wasn't hooked up to the ecu when I bought my car. Had to go through re-wire it into th ecu.
Now mine logs fine. Hope that helps.
Please answer
  • Where is the sensor mounted?
  • Does your wide band support narrow band simulation?
  • What version on DSMLink do you have?
  • What pin did you use to wire in your wide band signal?
  • Does your wide band need calibration?
