420A wide band / o2
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
Alright so I was taken apart my turbo and all that and noticed the wide band wires all 3 of them are running directly to the o2 sensor is that how it's suppose to be or can I put the red power wire and black grown to a power source and the black to a normal ground ? Where would the green go or should I keep that there
Not really like it's already there and set up but I was wondering if the power and ground is running to the o2 sensor I was just wondering if I can just shorten all the wires that's all or do they need to go to the o2
What are you asking? If you can run your wideband to what? Just power? The wideband gets it's reading from an O2 uego sensor. That's what makes it a wideband. Some people put the UEGO in the stock O2 sensor location, which will throw a CEL, or if the gauge is just spliced into the stock sensor then you have a narrowband.
