Wicked Wheel for a Holset hx 35
What turbine housing are you using just out of curiosity? If you're running the DSM-flanged .55 Bullseye turbine housing, a billet wheel is probably a waste of money....that housing doesn't really permit even a cast HX35 compressor to flow anywhere near it's potential.
Thanks for the response. I am running the .55 bullseye. I am still getting a little compressor surge, and I was wondering if it would help. I am using the tornado in the intake pipe and it is about 95% gone.
Does your HX35 have the surge-ported compressor cover? If it does and you're still getting surge, try dialing-in some cam overlap a little to reduce intake restriction. If you're still on stock cams, that's likely the reason you're getting surge.
I do have the surge -ported compressor cover. I also have HKS 272 cams on intake and exhaust. I have stock cam gears. I found most of the compressor surge was eliminated from the Tornado. Funny but it worked.
