2G Why won't my horn work and getting SRS light?
Pyramid
115
Mar 8, 2014
Topeka, Kansas
The airbag wiring and horn wiring are both in the steering wheel / column . Maybe a bad clockspring or something disconnected in there , you will probably have to pull off the wheel and take a look.
so if something is disconnected it wouldn't be under the dash? it would be in the steering wheel?
anyone else have some ideas / tips?
I am sorry that's its not the answer you want to hear but that's where both of those things connect and most likely where your problem is, they may just be unplugged but your going to have to pull the wheel off and find out. In the pic you posted the red and green plug in the steering column is the airbag and its plugged in, the horn / cruise control plug is next to it and it is plugged in. Does your cruise control work? it is connected through the clock spring too like the horn and the airbag. That big plug is your obd2 port and the small one that's unplugged is normal its not supposed to be plugged in to anything.
