Why won't it start?
DaltonB
Mar 22, 2011
Lanexa, Virginia
I have been working on a 92 Laser RS, and we have all the wiring hooked up and we made sure the timing was all right but,when we go to start it, the belts turn, but there is no ignition. We checked the spark plugs, they're working, fuel is getting through the fuel rail. My buddy thinks it could be the injectors b/c he doesn't hear a clicking sound when we try to start it, any suggestions? thank you!
i let the car sit overnight so the FPR read 0, then tried again and it read 40PSI and i also took one end of the rail off and fuel was definatly getting in, the engine turns, there is fuel, there is spark, but no fire. i'm at a loss
Also take a listen and make sure your MPI relay is working (clicking after you turn the ignition off).
You can also check to make sure the coolant tempsensor is hooked up. if theres no coolant temp signal to the ecu it usually wont start.
huh, i'll check the coolant sensor tomorrow aswell, we got a slightly mroe umphy noise, but battery died T.T so its charging, once its charged i'll try to start over, do you know which way the wires have to be hooked on the coolant sensor thing? i noticed it has a yellow and a green, or is that something else?
I tried everything but i'm starting to think its the starter because when i went to start it it made a clicking noise, and the lights flickered, i thought it was just b/c the battery might be dead, but after battery charged for 4 hours still same thing
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
