Why idiots shouldn't take apart cars
twisted_gears
116
Dec 23, 2008
Cincinnati, Ohio
I bought a clean 90 talon awd 96629 miles on the shell and came with the engine, trans, tcase, an almost everything to put it back together to make it run again. Altho he kept non of the bolts he took out of the car. this is what I've found so far.
New OEM Turbocharger Coolant Return Line (14b)
$17.99
New OEM Turbocharger Coolant Feed Line (14b)
$18.99
New OEM Transfer Case Bolt Kit - 90-99
$23.99
Exedy Slave Cylinder - 90-94
$19.99
New OEM Transfer Case Breather - 90-99
$12.99
New OEM Transfer Case Input Shaft Seal - MT 90-99
$5.99
New Inspection Cover for 6-Bolt M/T AWD
$5.99
New ARP Flywheel Bolts 90-99 6 or 7 bolt
$45.99
New OEM Starter Plate 4G63 Turbo 6 Bolt M/T
$21.99
New OEM Rear Main Seal Bolt Kit - 6 Bolt
$4.99
New OEM Water Pump Bolt Kit - 1G
$5.99
New OEM Oil Pump Bolt Kit - 6 Bolt
$8.99
New OEM Oil Filter Housing Bolt Kit - 6 Bolt
$6.99
New Balance Shaft Eliminator Kit - 90-99
$39.99
New ARP Head Studs - 90-94
$75.00
New ARP Main Stud Kit
$58.99
New ARP Rod Bolts - 6 Bolt Rods
$35.99
Graveyard Motorsports EGR Block Off Plate Kit - 4G63
$9.99
New OEM Engine to Trans Bolt Kit - 90-99
$12.99
New OEM Intake Manifold Bolt Kit (89-99)
$12.99
New OEM Turbo to Manifold Bolts
$23.96
New OEM Turbo Bolt Washer - 90-99
$7.56
$478 shipped to me. An I'm not done yet, I still need to find motor mount bolts or the size to find harden bolts from my local depot.
The dealer isn't always bad. I bought a 90 shifter cable bracket from them for around $18. It was cheaper than buying it at thedsmgraveyard and I didn't have to pay for shipping. Stupid 90's and their "unique" parts
Whenever i pull a part at the junkyard, i throw all of the bolts, and nuts in my junkyard toolbox. When i get home they go into the bin. This has saved me countless hours, and hundreds of dollars.
I'm guna start doing that now LOL.
