Take Apart Greddy Type-S BOV??
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
Yesterday I was under the hood doing something and I noticed that the hood has been hitting the adjustment screw on the bov so I took out the hammer and wacked that section of the hood frame in so it wouldn't hit.. I then adjusted the bov screw just to make sure everything was ok and when I was adjusting it the screw along with this small coil like thing popped out. I don't know how the little coil plays into the bov and how to put this back together.. any ideas on this??? :confused:
The Type S is pretty easy to take apart. Here is a link which shows the internals of the Type S: http://www.stealth316.com/2-greddy-bov-anatomy.htm
I'm not sure what the "small coil like thing" would be. If you only turned the adjustment screw, the only parts that could have come off would have been the adjustment screw, the locking nut (which prevents the adjustment screw from rotating), and a flat washer (located underneath the locking nut). You didn't try to remove the entire purple cap did you? If so, then the two springs inside the Type S could have sprung-out.
The purple top-hat is made of aluminum and its not smart to thread aluminum and put bolts in there. You can retap the purple head or buy some helicoil which are basically steel threaded inserts you put in there so things like this dont happen.
I just had to do this to my cylinder head last night on 3 studs :notgood:
Wait, so that coil was in between the adjusting screw and then purple top hole?? The thought passed through my head so I tried getting the coil back in.. but it's too big.. where would I get this coil??
I don't understand why this was constructed this way to begin with?? Why wouldn't they just thread the hole for the screw itself???
the part where the adjustmant screw goes in stripped out on mine so i was just thinking about buying an ebay knock off one and swapping the purple caps...any thoughts?
That actually sounds like a good idea.. even better you take the coil out of the knock-off and put it in the original..
Go buy your local parts store (O'reilly's, Autozone) and ask them to order you a helicoil kit for the specific size adjustment stud you stripped outta your bov. All you gotta do is drill out the hole in the purple top and use the threaded tap tool included in the helicoil kit. Then you use the other included tool in the kit to screw in the helicoil (steel threaded insert) You will then be back in business and better then new. :thumb:
If you click on the link I included in the second post of this thread, you will see the diaphragm. If you look at the first illustration shown at this link, the part labeled "rubber membrane" is the part you are interested in. This rubber piece seals the upper "chamber" of the BOV (the chamber inside the purple cap that is connected to the upper nipple of the BOV.)
Ohh, I was just wondering what that was. I don't need a diaphram...
I found kits, but what size do you think I should get??
My knock off greddy just came.. I swapped the cap and it's a perfect fit. My bov is like new again!
One thing I noticed: The knock off has a whole different way of sealing inside (pretty crappy, I'd never use it on my car) so the cap has large o-ring going around it. The real greddy does not have this so you have to take the o-ring out before you put the cap from the knock-off onto the real greddy bov.
If anyone wants to know... the seller I bought off of was "sgzimports" and this was the auction: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8077161400. This guy also ships really fast, it came from CA to NJ in 2 business days.
  • Wanted 6 bolt NT water pipe
    • chrisman287
