Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
Which turbo will be sufficient for consistent 11 second times? I've recently decided on a big 16g, but will that be big enough to run 11s with supporting mods and decent tuning? Remember, this is for a budget street car, so any one purchase over $1k is tough. A big 16g will run about $700-900, which is about $300-400 less than the larger alternatives.
Of course, I'll need lots of practice to run these times, but, I just want to make sure that it's possible before the money is spent.
. And you have safc2. You need atleast 650s to take advantage of the 50 trims potential. And that means running to the absolute limit of your safc compensation and scarry peak timing. The 50 trim is perhaps the highest flowing pump-friendly turbo out there. You can ramp up the boost to over 20 psi on pump and a good intercooler. and it flow almost 50 lbs/min. it is still within 70% efficiency flowing 47 lbs/min at 26 1/2 psi!. . .
