Where are the FWDs at????
Copy/Paste from FB - Ran out of time after 3 pulls. AFR was super fat 11.2:1, real conservative timing, runs cut short at ~7500 while we got the baseline in, never turned on the water nozzles and still made 410whp on 15psi! Fuel was E70" lot of power left yet in just leaning on the tune and winding out higher! This was a Mustang dyno.
Torque only trails off even the slightest because cells at that load past 7000 hadn't been tweaked yet.. which shows pretty distinctly on the graph LOL
E70
V3 SD
67mm Cast HX52 16cm T4
NPR 7.8:1 CR
6-bolt rods (ACL Grooved bearing/ARP Rod bolts)
Regular ARP Head studs
JMF Drag IM
Custom T4 Divided EM
Stock 1G Head
GSC S3s
Fidanza Cam gears (0* I / 0* E)
Kiggly HP Beehives
Kiggly HLA
Converted AWD Shep Stage 4
4.153 Final Drive FWD Quaife LSD
Water injection system was in car but not armed.. think thats all the relevant info.
Here's a gear calculator, it has Evo gear ratios in it as default, but you can put different values in.
This is also using stock sized tires on each car.
Speed . . . FWD Turbo DSM. . . . . FWD N/A 1g DSM
55 . . . . . . . . . 2250 . . . . . . . . . . 2375
60 . . . . . . . . . 2500 . . . . . . . . . . 2600
65 . . . . . . . . . 2750 . . . . . . . . . . 2800
70 . . . . . . . . . 2950 . . . . . . . . . . 3000
75 . . . . . . . . . 3200 . . . . . . . . . . 3250
80 . . . . . . . . . 3400. . . . . . . . . . 3450
85 . . . . . . . . . 3600. . . . . . . . . . 3675
And for full throttle acceleration considerations, here is a break down of what speed you are going at the top of each gear just before shifting to the next higher gear (assuming shifting at stock redline of 7,000 RPM) and what RPM you enter the next higher gear at.
Gear . . . . FWD Turbo DSM. . . . . . . FWD N/A 1g DSM
1st . . . . . . 39.8 (4125) . . . . . . . . . . 36.5 (4050)
2nd . . . . . . 66.9 (4850) . . . . . . . . . . 63.2 (4650)
3rd . . . . . . 96.6 (4900) . . . . . . . . . . . 95.5 (5100)
4th . . . . . .138.2 (5850) . . . . . . . . . . 130.7 (5650)
5th . . . . . .165.6 (N/A) . . . . . . . . . . . 162.3 (N/A)
Gear . . . . Turbo 24.5" . . . . . . . . . . . Turbo 26"
1st . . . . . . 40.1 (4150) . . . . . . . . . . 42.5 (4150)
2nd . . . . . . 67.4 (4550) . . . . . . . . . . 71.5 (4650)
3rd . . . . . . 101.5 (5100) . . . . . . . . . . . 107.7 (5100)
4th . . . . . .139.1 (5850) . . . . . . . . . . 147.7 (5850)
5th . . . . . .166.7 (N/A) . . . . . . . . . . . 177.0 (N/A)
*This will not account for tire growth at speed, it's just to show the difference between 24.5 and 26" tires*
E70
V3 SD
NPR 7.8:1 CR
JMF Drag IM
Stock 1G Head
GSC S3s
Kiggly HP Beehives
Kiggly HLA
Glad you got it on the dyno. I hope there is more in the 67mm hx52! I made 450whp @ 19lbs with the hx40. Hopefully you get more time to get the tune dialed in on the dyno next time out.
That's the oddest looking Mustang Dyno chart I've ever seen! :D
(where's the :brainfart: smiley?)
LOL
Fair enough, looks like I had one too!
Finally something more substantial than a still of a partially disassembled engine bay:
Exterior:
[ame=http://youtu.be/JtP0aJ2ZkyQ]Cold Start HX52 1G DSM (Exterior) - YouTube[/ame]
Interior:
[ame=http://youtu.be/hUjuj1ADGeg]Cold Start HX52 1G DSM (Interior) - YouTube[/ame]
(forgive the GoPro rattling..)
Hopefully I can get out and tune a bit this weekend and get some action shots. Should get a proper dyno session in on 11/9!
Chris, is your HX52 a cast wheel like you said? All eight I have had my hands on have been billet wheels. Not that it makes them anymore special. Just a different manufacturing process for durability.
nice to see some fast FWD hope to get mine dyno'd and tuned soon running 12.02 at 116 on my evo16g hope to have my 6262 on this week, so glad to see im not the only one who wont go to the darkside "AWD"
Missed this the first time around, sorry!
Drove out to Boostin Performance:
Found my base timing (CAS) was 4-5* retarded, fixed, made a pull.. on gate pressure she made 325wtq on Boostin's Mustang Dyno, vs. 301wtq on A*spec's DynoJet. So picked up a good deal on just that alone. Still real fat AFRs ~11.2:1. Boost controller installed, thought we turned the knob all the way down and made a test pull then suddenly saw a 38psi spike and got out of it.
MBC Knob had come un-threaded LOL some loc-tite and a few turns later we went to make another test pull, got to 20psi (only 4000rpm!) aaaaand the lower rad hose decided it wanted a day off. So we got some new -16 hose in the mail and we'll try again this week.
Uploading videos of both (partial) pulls later tonight! :thumb: You could feel the pressure change in the room on the brief 38psi spike :hellyeah: Spool is just unreal for a snail this size, now that the MBC is keeping the gates from cracking prematurely. Devin was pleasantly surprised by that too, compared to having previously had a T3 6766 on the Red Demon
Did a little math with yesterday's new 15-16psi numbers. Though they mean nothing without ET/Trap MPH.. Conveniently, her first run off the wastegates had a ~7000RPM shutdown making these figures easily compared to what it made at the same engine speed on the DynoJet.
So on the DJ 224(?):
409whp/301wtq @ 7100
Today on the Mustang 500-AWD:
439whp/325wtq @ 7100
Using 9-11% to convert to DJ numbers gives about 485whp/357wtq! Not bad for ~15psi, fatty AFRs, conservative spark and only 7k rpm :D We will lean on it harder once the hose is fixed!
We had discussed running out to somewhere in the neighborhood of 8500-9000, leaner and at least 5psi more boost. Depending on torque, we may add timing and see what happens. Not sure if making much more than 400wtq on Boostin's dyno is wise with that much rpm on this "stock-ish" block. Probably pushing my luck.
Can't wait to have a rotating assembly that can handle that 40psi from a turbo like this, more than once or twice that is ROFL
Click to open videos.
20psi Test:
38psi spike:
This motor was built in the garage and has outlived two chassis, three gearboxes, several heads.. had nearly two dozen combinations of intake/cams/exhaust/turbos strapped to it in that time LOL
It survived a T4 GT4088 at ~30psi, and most recently my T4 S200sx-59 on kill mode at 37-38psi. This setup will probably be the straw that breaks it's back.
As far as everyone's concerned.. it's given me my money's worth!
Just as well though that we can't just up the boost. There's a lot of development and testing needed, both chassis and driver. More power may mask shortcomings on my part.
Soon as the other shortblock is done, we'll crank it up! :hellyeah:
You should make a table outta the old motor ..haha
Can't wait to see it all done nice work
Thanks!
I'm curious to see where we decide to end up stopping for the year. Even limiting it to 400wtq (on the MD) at high enough rpm will make a ton of power.
For example..
400wtq @ 7500rpm = ~570whp
400wtq @ 8000rpm = ~610whp
I was trying to get the car tuned for IFO vegas But we ran into some issues. but hopefully we will be doing some off season testing this weekend.
You guys keep showing up with these masterpieces and reminding me how much exterior work there is left to do on my pig :sosad:
LOL now if only we can get it to the track and make some passes, would be awesome!
Landspeed you know we have mad respect for your setup but I must say shorty got a point! Are you like me I want to go back to the dyno because I know l can make 700 but I don't want to risk breaking something to do it? :) quite playing and turn that boost up and let that car roar!:D
Lol don't worry its beautiful weather here and our tracks closed too! :( they are supposed to be repaving it but its taken them a year already and it's not even close to being done LOL! Kinda like my car haha ;)
Shorty the car is looking sick! It should be into the single digits first pass. What converter do you have in there.
Good thing the track is open year round here in south florida!!!
