Where are the FWDs at????
Got my car out to the local track Saturday. Still have a lot of work to do on my 60ft. Got in 7 passes and was able to set new PB.
Looking for QUAIFE OR equivalent diff and axles for sale.
Also advice on tires for 1/2mile event
I have a 1990 GST..
Nice times What boost are you running on that Black? How are you liking it with the 2.3? I run the 76HTZ Red and have considered going 2.3 when I rebuild the bottom end.
Still getting faster. Had a 131mph pass as well. Found a weak link finally though. Driver side CV shaft broke. Any other fwds still making passes?
This was on 30psi, I've been up to 36psi but have been having issues with dropping fuel pressure. I have no complaints on the 2.3. It's been solid and done its job. I have boost by gear but I'm not even using it. For the most part it's only spinning a bit in 1st. What about you any track times?
I haven’t been since the Red was put on. Last year first time I ever ran it at the track was on the 68hta V2. I got 4 runs and I was unprepared for how good the slicks would stick and I bogged off the line but best of 13.1 at 112. Looking forward to upping the rpms and seeing what happens now that I’m running the Red.
Nice seeing fwds still out making good passes.
Mines been tore apart still since I got the cage done. Hoping to drop the engine in over winter and make some passes next year.
A cage is what I need now if I try to go any faster. I'm pushing it without a cage already. Haven't decided if I'm going to go auto awd or just stick with the 5 speed fwd and chip away at my times.
  • Wanted 6 bolt NT water pipe
    • chrisman287
