- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 50-trim
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- FP 76htz Red,Fp intake, RVR intake manifold, heat barrier gasket, Punishment racing radiator and slim fans w/shroud, walbro 255, aeromotvie a1000 fuel pressure regulator, fuel lab 818, Fp Race Manifold and turbo lab blanket, tail MVS with Jm fab recirculated o2 housing, BS FAB side exit exhaust , vr speed short route fmic, hks ssqv, s90 throttle body, FIC 1050cc injectors, erbified motorsports coolant overflow tank, custom cold air box and ducting to the intake
- Mods-Engine
- Stock 7 bolt, rebuilt head with GSC S2 cams and GSC springs and retainers. ARP head studs, Kiggly upgraded hla
- Mods-EMS & Logging
- V3 Full, innovative lc-1 wideband, prosport evo series boost and oil pressure gauges
- Mods-Drivetrain
- TRE stage II rebuild w/ 8% taller fifth gear, Wavtrac LSD, Competion stage 3.5 clutch, competition flywheel. SS clutch line, Prothane motor mount inserts, shifter cable bearing mod, symborski kit
- Mods-Handling
- Evo Recaros black leather, Feal 441 road race spec coil overs. 13k front 6k rear,Full poly bushing all around, RM front sway bar, 3g rear 19mm rear sway bar, Dc sports strut tower braces, outlander front brakes with EBC red stuff pads w/ SS lines, Early 95 big vented rear brakes, street setup Enkei RPF1 17x9 +35 with 255/40r17 Toyo R1R. Strip setup 15x8 +40 Rota Slipstreams with 24x8.5r15 M&H Racemasters
