whats this nipple on the back of the intake mani
RossY
627
Sep 27, 2002
Canton, Ohio
what is it and what goes to it.
:banghead::banghead::banghead:
Yes, that line is supposed to be hooked up to the nipple. The nipple off the intake manifold provides the vacuum for the brake booster. The hose itself from factory has a built in check valve inside the hose.
If the hose is replaced with a regular hose NON OEM then you need to install the inline check valve by cutting the hose in half and putting the valve in between the two pieces.
I don't know how much clearer I can make it.
Here is a 2G setup with the large nipple on the intake manifold closer to the throttle body; obviously the hose and position of the brake booster are exaggerated a bit:
Here is a 1G setup with the large nipple on the intake manifold closer to the timing belt:
You should only have one of these, not both.
Anyone by chance know the thread size and pitch of the Brake booster vac nipple? I think its either, 1/8 BSP or 1/8 NTP. Thanks
jj2gdsm - There is no nipple there on the 2G manifold. Only a boss casted in.
I don't think it's that small. I'd guess it was closer to 1/4".
The first pic hose nipple is definitively the brake booster vacuum line. You must have the inline check valve in it to prevent issues.
Well JNZ has a replacement vac fitting for the PCV valve that is 1/8 BSP and this vac fitting fits in there. I just don't know if they are the same pitch and I don't want to force it and ruin the threads of my spare valve cover. I do believe the 1/8th measurement is the internal bore not the outer diameter but I could be wrong. I guess I'll just have to have it measured at the shop downtown.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
