99gst_racer
Moderator
- 12,010
- 1,706
- Apr 5, 2003
Coloma,
Michigan
What sensor is this and what does it do?
IHeartTurbo said:Manifold Absolute Pressure or MAP
An MDP is the same as an MAP. Just the MDP reads pressure as well as vacuum. In essence it is the same thing. And no, it doesn't just ensure the EGR is working. When the key is turned on, it reads barometric pressure. And while the car is running it reads pressure/vacuum in the intake mani.Syndicate13 said:Wrong. It's the MDP or Manifold Differential Sensor. All it does is ensure the EGR valve is working. If you unplug it you'll get a CEL.
