Whats Parts Will Swap Over From My 1g 7 Bolt to 6 Bolt?
spadepro22
1,206
14
Mar 13, 2008
Seneca, South Carolina
The title sums it up, going from 1g 7bolt to 6 bolt. What parts can I keep since the 1g 7 was just rebuilt. Talking parts like timing stuff, timing lower cover, water pump etc, you know, the small things.
Youll need a new tstat housing, waterpipe, lower radiator hose, intake manifold, maybe throttle body, and thats probably it. Anybody think of anything else?
The head bolt holes will need reamed out to take the 12mm bolts/studs of the 6 bolt.
The timing belt, but the auto tensioner will not, Not sure about the tenstioner and idler pulleys.
The intake manifold might be the same 6 or 7 bolt 1g..I know some folks use the 1g 7 bolt head on the 2g..It does have the large intake ports like the 6 bolt(snowboarder)..But like Bogus said the studs are different..
Little stuff like boost piping, interior, that stuff is all the same..When I think little stuff thats what I think of..
Nope, I didn't do that. I had a full 1g 7 bolt setup with a 1g head (larger ports). No mixing and matching parts for me.
The intake manifold will be the same. Port differences are between 1g and 2g heads, not 6 bolt and 7 bolt heads.
All of this is the same. Its a 1g 7bolt.
I thought u had the 1g intake manifold..Maybe it was just the manifold and not the head I was thinking aboot.
Yep, 1g 7 bolt also had 1g 6 intake manny. The 2g 7 is better.
2g head being better is still being debated..Not a bad idea for anyone tho, and a definate upgrade to a stock auto 1g..Swap in some 1g 5 speed cams with that 2g head on that 1g auto..And,Ohh crap I'm ranting allready today..ROFL
If the 2g head debate was as simple as upgrade for 1g auto, vs 5 speed etc..Maybe you wouldnt get so many this head is better hands down type deals..
I was referring to the 2g intake manny being better.
