swapped 7 bolt to a 6 bolt
cal92talon
Mar 29, 2010
lancaster, California
installed 6 bolt engine w/ new flywheel,pressure plate, clutch,both master and slave cylinders, bled the system. wont shift into any gear w/o grinding also no play in clutch peddle. ive asked everybody, need a little help.Please!
I bought an ebay xtd clutch before, did the same exact thing, the disc was not machined right and would not slide easily on output shaft of the tranny
