What did you do to your DSM today?
LOL
Yea that part is cooperating pretty nicely, the front of the car needs a little love. There is a bit of a crack on the lip, lower driver side area that I'm trying to find a fix for.
But I am adding some block-offs like you can see one Devin Schultz's 2G and Joe Bucci's 1G
Going to run from the edge of the opening and stop right at the beginning off the tube/fin section of the core. Thinking about using a flat black thick vinyl.
I made the opposite of a block off..I made a sheet metal bottom add on to the front bumper..So it goes from bumper to a cross member and then goes back and stops before the front tire..
Third meth nozzle is now in the pre-turbo pipe
All meth lines run
^ very clean
Towed my car on a car dolly... That was nerve wrecking since we had to push it up onto the damn thing. Put top down for the 2 hour haul to dry out the inside of the car...
Extremepsi.com visited, and ordered new clutch kit and all the goodies that go with it. Thanks Hung!
Products ordered
SKU Product Item price Quantity Total
MIT-MD719602 OEM Clutch Pivot Ball : Mitsubishi Eclipse 90-99
MIT-MD718077 OEM Clutch Release Boot : Mitsubishi Eclipse 90-99
EXD-05048 Exedy OEM Replacement Clutch Kit: Mitsubishi Eclipse 90-99 Turbo
MIT-MD770506 OEM Clutch Release Fork : Mitsubishi Eclipse 90-99
MIT-MD706185 OEM Clutch Release Clip : Mitsubishi Eclipse 90-99
MIT-MD742053 OEM Axle Seal Front Side : Mitsubishi Eclipse 92.5-99 FWD
MIT-MF472404 OEM Flywheel Dowel Pin: Mitsubishi Eclipse 90-99
ES-5.1103G Energy Suspension Motor Mount Inserts: Mitsubishi Eclipse 95-99
Options:
Color: Black Inserts
PSI-Decal Extreme PSI Decal
MIT-MD749998 OEM Throwout Bearing : Mitsubishi Eclipse 90-99
Parts arrive on Thursday. Damn I love that place.
F
GREDDY FMIC will be installed again, radiator checked for leaks, and rubber replaced, and that damn boost leak/spike issue will be fixed in a week. As well as the b&e shifter connection.
Just need a replacement sensor for the glowshift wideband I found in the car, and I can start playing with my ceddymods and evoscan. Can't wait to get to tuning. Anyone selling some FIC 770's for the low low?
I really missed my baby. Can't wait to clean her and boost her.
Installed CF hood w/ aerocatch hood pins
Re-wired half the car pulling out an old aftermarket alarm system that was killing the battery
Installed FD3S wheels
Filled it up with 93oct
Sprayed some 4-ease in the locks (it's magic in a can I swear by this stuff)
most of this I forgot to post
installed dejon intake and breather on VC
replaced shitty two prong weirdo spark plugs with ngk bpr6es
replaced lower injector seals to fix boost leak
lost a fuel rail spacer :(
Got my WB in the mail,I pit it in the prototype center vent, and here is the outcome of that.
Installed my Koni Yellows with Tein springs for a 2" drop today. Pics tomorrow in the daylight. Nice ride now though.
