What did you do to your DSM today?
Finished re-installing my head after shearing teeth off the t-belt awhile ago. Bumped the valves when I tried to start the car when it died not knowing what happened. No head work at all back together and runs great. Got lucky LOL
Bought another door handle. Someone attempted to break into it and snapped the door handle clean off. I had the RCAZ reinforcement kit installed too. Nice huh?
cranked it to build oil pressure for the first time on the engine. also tested ignition coils at the same time.
nest is to finish a few small things and fuel it and check fuel and start it.
Relocated my alternator to the rear of the motor
then she sliced my thumb open while removing the ps cooler.
made a fuel filter banjo bolt after breaking one that come with my pressure gauge trying to stop the damn fuel leak.
For my talon I replaced both front wheel bearings and cv axles as well as the master clutch cylinder, bled my brakes and clutch then i drove it out of the shop for the first time ever and washed it. now im waiting on over 1700$ worth of parts that i just ordered to finish it! :hellyeah:
Pulled my first engine/transmission!
cranked and started it for the first time. now if i can get the dsmlink to cooperate and the mpi relay fixed i can keep it running
got the ball joints and front energy suspension motor mount in. OMG it handles like its soppouse to over bumps and pot holes and the car feels solid and the engine vibration has gone down now woth rear and front energy suspension inserts and side drop enginering tranny and motor mount.
Changed transfer case and diff fluid. The transfer case was a bit of a PITA and didn't seem to drop or take much fluid. I believe I read it is suppose to take about .5 qt to .63 qt???? Have got most the "maintenance" items done now so I can start working on mods. :hellyeah:
Also gave it a bath.:)
Got my FP 255 fuel pump today and waiting on K & N RU-3480 and adaptor to show. Thinking of getting the VRSF FMIC and then I can install my 1G BOV, get it tuned and continue the build.
Ripped out all the carpet to get ready for my batt. relocation. Oh and put on a clean tow hook. Not too shabby. :thumb:
Just fixed my water pump pulley. It was making a terrible squealing noise. Took the time to check it out and I put it on backwards! So after shaming myself I fixed it. Sounds WAY BETTER!
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
