What block is this?
88BB8B
179
19
Oct 14, 2016
Coldstream, BC, Canada
So it was my understanding that turbo blocks have a 4G63T stamp on them, and the N/T have a 4G63 stamp. I was also under the impression that one of the few differences between the blocks is that the turbo blocks have oil quirters and the N/T blocks don't.
I was worried about piston heat because my block has the 4G63 stamp, and is going turbo with an HX35 (Turbo or aftermarket internals) and I didnt see the normal oil squirters you see on the turbo blocks, but then I noticed these guys.
These definitely look like oil squirters to me, but not like the ones I've seen before.
Again the block says it is non turbo on the stamp. Are they aftermarket? (Machined in?) or is this something mitsu did to this block from the factory?
Okay. My machinist told me that this block was lacking the "T" on the stamp and, therefore, the non turbo model.
I didnt know the 7 bolt oil squiters were like that, that clears things up, thanks guys.
My blocks don't have the "T" on them either and that is a 7 bolt block. The lack of "suit case" handles for the mains is a dead give away too. Just fyi.
4G63T is not an actual engine code, so your block will not have the T engraved on it unless it has been added by someone after the car left the factory.
A 4G63 block is, forever and always, a 4G63 block. A turbo block has some extra machine work but is still, at its core, a 4G63.
really confused about 4G63
Block Identification
Also - those are only factory oil squirters for 2G turbo engines. The 1G 7-bolt engine had a squirter similar in style to the 6-bolt. :thumb:
So this photo is from my 90 gsx. Pretty certain it's the original. It also has 4G63 without a "T". What is the deal with the JH0803? Any meaning there? (You'll have to zoom a bit on the photo to read).
I've always wondered about the extra numbers too. Would definitely like to see info on it.
This info needs to be corrected a little. Not all turbo 7 bolt blocks come with the 2g style oil squirters like the pic you uploaded above. 1G turbo 7 bolt, EVO 1/2/3 and some RVR come with the 1G style oil squirters.
I always write those down on my build sheets along with adding my own build #'s but I would guess they are just engine ID's as they come down the line.
decoding engine block numbers
These screen shots are from the Chrylser PDF for the 1G, which can be referenced at: 1G Plymouth Laser and Eagle Talon Factory Parts Catalog 1990-1994
So it's the serial number. And at some point, from all the information I've seen and been able to cross-check, the serial number ends up meaning something.
You always come up with the coolest shit Brian!!! :thumb::thumb:
LOL
I used to have a lot of time and did a lot of research into these things. I will say, at this point, this one's still a theory which I put out there for others to check against. Everything I've been able to find seems to line up so, from my experience, it's another 6- or 7-bolt check for engines that originally came in DSMs.
Marty, you said you write these down for all your builds? Want to run those against the NH0001?
MR8102 - 1992 Talon Auto block
JQ8267 - Replacement for 1990 Talon TSI
QX9023 - 1995 7 Bolt Talon TSI
2 more coming that I didn't have written down because they are not built yet.
HW 5316 - Original 1990 Eclipse GSX engine
KL 4506 - Built4G63 block
MJ 1541 - 6 Bolt from Arkansas
Yes, it was the first 4g63 motor I had and I bought it from Built4G63. The rest are all my blocks and my builds. I never knew where that block came from.
Very helpful. I had noticed that note on occasion about "up to NH0001", but without knowing how the code sequence worked, I couldn't tell how my engine related to it. I always figured that since my car was built in fall of 89, it applies to the "up to xxxx" and not the "after xxxx". Thanks also for the link to that source. That's going right on my phone. I spend hours scrolling through those exploded diagrams (classic enginerd!).
Wonder if they skipped a lot of possible codes in the series, since my 1989-mfr block would be somewhere in the 2.5-Millionth unit produced. 10,000 per second letter [AA to AB], so 250,000 per first letter [AA to BA], so 2,570,803 blocks before JH-0803? That's a lot of blocks. I know they did use them in other vehicles, so if they started in earlier in the 1980's, I suppose that makes sense.
