**Video** Launching Auto DSM with nitrous comparrison
Seems to be a whole lot of "I read this" and "I saw that" in here and not a lot of actual experiences.
I agree. The way his nitrous is setup is obviously working. Why are you guys trying to tell him to change it. Especially people who have no experience in running nitrous with an auto. The best way to run a single fogger nitrous kit to stall an auto car would be a dry shot near the throttle body. You can add fuel and pull timing through the ECU. If your tuning equipment cant do that, then this is the next best way. A wet shot on a button.
That holset its just waking up at 28psi.. The taper is from a crappy boost controller... Get it up around 35-40 and hold on... Btw I offer a 10 inch converter. 3500 instantly creeping to 4k spooled a hx40 to 25 psi in10cm housing around 4 seconds. With no real stall tuning. Still drives great on the street. Pm for pricing
I dont know, definately maxed out on flow. should only flow 52lb/min and i am seeing 52-54. This is an 8 blade setup. I'd like to try an ebc but its not worth the cost right now.
Also my hallman pro with the same setup would hold 28psi solid last year. Just as soon as we turned it up, it started having taper issues.
And I see someone who didn't even contribute anything.
I did contribute. Since you were too ignorant to see what I contributed, I will go ahead and spell it out.
"I read" and "I saw that..." has far less value than "based on my experience." The rest is hearsay, and really has no value. Why clog a thread up, especially one that is meant to be informative based on ACTUAL EXPERIENCE, with a bunch of unsubstantiated garbage?
It seems this guy gets it.
