1G Very low compression - no start
91tsiawdtalon4g63
168
24
Dec 24, 2013
Brownsville, Pennsylvania
1990 gsx, 0 mile only idle time 6 bolt block I bought from a reputable seller in the community. 6 bolt cylinder head, new topline lifters (bled before installed), kelford 272s, oem valves that were lapped in by myself and my friend. Brand new gsc beehive valve springs and retainers. Brand new 9627pt felpro head gasket with L19 studs torqued to 115ft/lbs, brand new timing belt pulleys tensioner etc.
We fully assemble the entire build and drop it into the car. We gap brand new plugs and toss them in and hit the key. It cranks but doesn't fire up so we wait a little then it finally fires up for 5 seconds then dies out and won't even try to fire again. So we pull the head thinking bent valves but all the valves are 100% good, then we think maybe timing belt slipped but everything lines up and belt is 100% good. We run a compression test and get 40-75-40-100 (1-2-3-4). It's a fresh block so rings aren't seated yet but we have zero idea what is wrong that the car won't even attempt to fire. My friend and I have spent 2 straight weeks mulling and replacing parts that we would even suspect to be the issue yet absolutely nothing has changed anything.
We did a poor man's leak down test and it is coming from the oil galleries in the head to indicate rings but they're not seated so I'd assume that they should leak right now. The pistons are wossner with eagle rods. Unknown on specs from the rings as it was built prior to me owing it. Cylinder walls look excellent.
I asked the seller of the block his opinion on this and he says that it sounds like valvetrain. So before we swap all the goodies to a different head, Any input would be great to solve this huge PITA
Crank plate is 100%. Exhaust isn't plugged anywhere. Block is in fresh condition so probably was milled a little bit whenever it was first built. The head is in good condition but not sure if ever was resurfaced or what not, I'm running 9627pt felpro head gasket. Filling the cylinders with air has each cylinder spilling the air into the oil galleries with the cams out.
Compression went do to 25-45-45-25 upon the new head being put on. So it was significant. I suppose the first head we put on wasn't in better condition than the one we did put on but at this point I'm blaming the piston rings. The car is getting towed tonight to the seller of the blocks house cause he says that the block is healthy so I'd like him to go over everything to see if my buddy or I missed something or what not.
Timing 100% also. Honestly the only thing we didn't check was the piston rings whenever we put the car together.
Could the cams be the wrong ones perhaps? Honestly nothing at all should make this car have such weird crazy issues. My buddy has been dealing with the cars for over 12 years and i've been in them for 5. We've had weird stupid issues before with the car but this is by far the biggest one that's kicked our butts badly
Went to the sellers house tonight after work. He is suspecting head issues but isn't ruling out the piston rings, that they maybe stuck or corroded or such. He doesn't have the time to pull it apart to look it over so in the next few weeks it'll be towed back to my house so I can pull the pistons out to see how the rings are. He was cool with me about everything and says if there is something that is bad with it, he will help me out with fixing it.
We made sure everything was in time and everything then tried to crank it over again and it's blowing fuel fumes out of the crankcase. Like my car was vaping that's how bad the crankcase fumes were coming out of the valve cover. Not sure if that rules out anything or brings something else into the equation...
