1G Low Compression & Knock
Jdabishop
136
Nov 9, 2012
mesa, Arizona
Ok so I initially had low compression on number #3 it was coming out to 70 where as the rest were sky high and perfect. Well then it had a knock later on down the road so I along with others assumed the knock was a spun rod bearing.
Well I just tore down the engine and all the bearing looks great nothing that I see that would cause it. So my question is what else could it be causing the low compression and the knock? I cant think of anything else besides possibly the timing skipped but would that cause an engine to knock?
Thanks,
Justin
A bent valve would also explain low compression in that one cylinder. If timing skipped, I would expect damage to all valves/cylinders.
You know the cylinder with the issue, #3 Low compression could be from a valve that is not seating properly.
Mic the piston and bore, you may have clasped a piston skirt, or have a wrist pin issue, both of them can cause a knock
