- Thread starter
- #101
AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
I only said it because it's no big deal to remove the gear if you need the room. There is no why.
OIC
Necessity is the mother of invention Tony.....good god that is quite a conglomeration but if it works, hey, I can't say a thing!!!
. Needle bearing also looked great. First and second have the same amount of play as the last video of third. Lock ring fits perfect but I haven’t measured the end play yet.If they used the shallow 1st synchro then there should be no issue with double springs on the hub and slider keys per side. If it is the tall 1st synchro it would only use 1 spring on the 1st gear side to clear the synchro. I don't see anything really out of the ordinary from those pictures. Just make sure both sides of the hub are not galled or groove on the thrust face against the gears.
As for the snaprings, typically the 1.5mm snaprings for both the input shaft and intermediate shaft are the ones I normally use.
I used cheap calipers before and got 9.1mm. This is closer to the shorter one.
