- Thread starter
- #76
AWD-Tony
- 6,787
- 3,748
- Sep 11, 2017
Cincinnati,
Ohio
I havent replaced any needle bearings ever. I dont know how to determinate if they are bad if shaft looks shiny after cleaning and bearing turns freely. That bearing is hard to remove as it does not fit to common hydraulic press and pulley is smaller than the gear. If you can use those long bolts to hang it in to press and use some wrench extension to press from axle it could work. Its pretty loose once it gets going.
Im replacing the needle bearings since I’m 90% there. The needle bearing for the output shaft is no longer available, that’s why I’m asking. This puller is too small for this job since I can’t even bolt them together. There’s no way to use this puller on the press. My buddy has a larger set so I’m borrowing it tomorrow.
