TO4E install help
JDR7919
301
Jan 1, 2005
Titusville, Florida
Im trying to install my 30r without denting the water pipe. I have read a few post about exhaust manifold spacers and was wondering if anyone know where I could pick one up.
Hahn sold them but I cant find them on there site now.
Any help or ideas would be great thanks.
Hahn Racecraft - Turbo Upgrades and Parts
Scroll down a bit, and you'll find this. A quick google search does the trick..
"Spacer Plate, Mitsubishi Exhaust Manifold: This laser-cut, .500" thick plate spaces the exhaust manifold forward when employed between the manifold and the head. Uses two exhaust manifold gaskets shown above. This plate creates the extra clearance needed to install larger turbos without interference with front of engine block. See Super Turbo hardware section for the longer studs you will heed to use this plate.
H TZ-7330: Spacer Plate, Mitsubishi Exhaust Manifold"
Thanks for the help!!!!!
I'd just dent the water pipe, its not a big deal.
