plug a factory water line? to4e install problems
Status
Not open for further replies.
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
I'm in the middle of installing my oil cooled [to4e] G50 into my 2g talon and it's being a big PITA. I have to dent the water pipe among other things and the compressor cover is ALMOST fitting but the banjo bolt [one of the original factory water lines to the turbo] from the block is hitting the compressor cover...
Can I plug that original location up with a brass plug and cap off the other water line?
or should I just route those two together and grind down the actual banjo head?
btw, the banjo bolt is located DIRECTLY under where you would need to dent the water pipe...
WOW you waited a whole hour and 47 minutes for someone to reply. Not everyone sits at their computer click the "new posts" button.
Yes, you alreay know you can block it off.
Status
