BLACK'98DSM
Moderator
- 5,519
- 3,053
- Feb 9, 2019
Alabama
When going in reverse, the car makes the loud whining sound. The odd thing is when I push the clutch in the sounds continues. It does not continue after the clutch is engaged on the other cars. Also sometimes the car wants to grind into gear. I will have the pedal to the floor but still sometimes misses a gear. I noticed If I wait a second after pushing the pedal down it goes fine, but doing it quickly misses gears. I have not noticed any chattering from the clutch, but sometimes If I let the pedal out slowly it still throws the car forward with a hard jerk. I have replaced the slave and master cylinder, so both are new. System has been properly bled and topped off. Could this be the clutch fork positioning? Does the master cylinder require adjustment? Or is this just ultimately my clutch?
