Tial 44mm vacuum fitting?
Ludachris
Founder & Zookeeper
8,934
4,909
Nov 12, 2001
Newcastle, California
I saw an EVO in a magazine that had changed out the banjo bolt fitting that comes with the 44mm wastegate to a 90* AN fitting. I'm thinking of changing to a metric to barbed elbow. Anyone know where I'd find something like that? I believe it's an M10x1.25 thread.
That wastegate should have come with a 10mm banjo and fitting that makes it kinda into a 90*. You should just be able to get a 10mm banjo to -3 or whatever and do it that way. Will that work for you or are you looking for a one piece fitting that threads in and is a 90 also?
I can't seem to find such a fitting, and TiAL says that thread is 10mm x 1.0 (which makes it all the more difficult).
I can do it with 2 fittings but there isn't much room. The Evo I saw had one fitting, but it was an AN 90 degree fitting. I don't know if I want to run steel braided line for that.
I sent Tial a note to see what they say. I doubt they'll have a solution though. I guess I could always just use Loctite.
I found the correct fitting but it is about 2 days out. It is a 10mm x 1.00 to a -4 but it is straight. It has a sealing washer on the metric end where it would go into the tial. If you need the 90* fitting I can get you a 90* -4 to -4. PM me if you want more info.
Wayne
Wayne
Thanks Wayne, but I don't think it will work. I don't have enough room. It's got to be a 90 degree fitting coming off the wastegate for it to work.
  • For sale 1g 1G AWD Fuel Filler Neck
    1G AWD Fuel Filler Neck $75 + shipping & paypal fees* I would replace the rubber elbowYou...
  • For sale 1g 1G 4 Bolt LSD Rear Axle Set
    1G 4 Bolt LSD Axle Set $120 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
