1SloEvo
- 1,068
- 22
- Mar 7, 2010
Warner Robins,
Georgia
Did some testing today on my fuel system...and found out some pretty cool information. I am running a walbro 400lph pump, 865cc injectors, and the stock lines, rail and regulator. The tune pneumo did on the car was very solid, but the idle was rough...due to overrun of fuel by the fuel pump on the stock regulator. So I bought an adjustable regulator. Even at 43psi of base pressure, the car was running a bit lean. So I made a setup tonight to test the fuel pressure with the stock regulator and a single walbro 400lph pump. 50-51psi is what I got. That's right...50psi of base pressure. The pump is great...but the stock fpr just can't handle it!
but i'm just doing the best i can while having fun with it
In theory, 10 or 11 to 1 should be best, in reality, most people do it on a very reasonable compression (8-9 to 1). Much it comes down to weight, a true street car might have a hard time touching the record because of weight, but not because of the engine.
