Testing 90 model TPS
AWD 90 Tsi
48
Sep 5, 2006
Oklahoma city, Oklahoma
How do you properly test your tps, I have the 90 model so I cant find a article on how to do it my prongs are like this
12
34
Please let me know thanks
First check the TPS resistance with the trottle closed. Connect the probes of an ohmm*eter to terminals 2 and 3.
It should read 3.5 to 6.5k
Then check the TPS resistance through a complete range of open and closed throttle.Unplug the electrical connector and connect the probes to terminals 2 and 4. Slowly move the trottle valve and observe a distinct change in resistance. It should range from 1,100 to 5,600ohms.
Check the wirring circuit, by probing each terminal and check for signal voltage with the ignition key in ON. It shouldbe approximately 5.0 volts.
