90 TPS help!
way2slowtalon
147
Oct 24, 2004
Newington, Connecticut
My tps reads 0 on my afc1, and 10% on my datalogger, and does NOT work at all. Im confused where my tps cable goes because it goes in between the intake manifold and disapears in the back somewhere.
How can I test this thing out without ripping of my manifold?
Thanks
10% is actually a normal reading your tps at idle, all tho it should change as you push the pedal, also theres are page in the apexi manual that shows you ahow to set it up on the afc....
Oh i know 10% is normal, but when I give it gas it wont move from there. My ISC works which is wierd but when i give it gas, the rpms actually drop than pick up. Any clue on that? I'll check Apexi manu online.
