1G 90 TPS adjustment
nube90
386
Mar 16, 2006
terra alta, West Virginia
Ok I need some help with the TPS adjustment I cant find where the pinouts are or where im suppose to connect the ohm meter at Ive already been to the Vfaq and searched the forum but nothing came up there is a right up on the Vfaq but my TPS is different than that one.
Check your shop manual but the procedure should be the same. I know the pictures look different but 90s have the same 3 wire setup just as the 91-94s do. Trace the wires coming form the TPS back and you should find a 'quick disconnect'. From here you can jumper the wires using alligator clips and then take your ohm meter to test the voltage and resistance to ensure its within spec.
Looking at the connector:
1|2
3|4
Attach jumpers between connector and tps. Use voltmeter to check output at pins 2 & 4, voltage should read between .48 - .52 volts with the throttle closed.
