2G 2G TPS adjustment
shshfbdicn
Mar 27, 2024
alburtis, Pennsylvania
Is there only one way to adjust the TPS? I have a apexi boost controller that also tells me any other info I want and I can look a my throttle %, can I use this to adjust it?
For example when I turn the TPS with the pedal down the percentage on the screen changes. Can I go by this to adjust it, because when I do it the normal way my car seems to not run right.
Could this be because I moved my throttle stop screw to make it idle?
Fix the idle stop first. You should not mess with this to achieve idle.
I don't know how the screw is supposed to be adjusted and my car would not possibly idle any other way without turning that.
I changed my idle in ECMLink and it does nothing. No I don't have a vacuum leak either.
Read this. Do you have the ground strap the connects the throttle body to intake manifold and the strap from intake to firewall? Post pics.
Also please post a vehicle profile. We do not know what car you have and what mods.
