Testing 90 power transistor
kneipperk
214
Oct 25, 2009
aurora, Colorado
Ok so this might sound dumb, but i did a mostly stock rebuild on my 90 tsi over the last 5 years and finally got around to finishing it up. When i tried to start the car i got no spark on all 4 cylinders :banghead: I know the coil pack is 2 seperate packs and the chance of both of them going out at the same time was kinda slim, So im trying to test my 6 pin power transistor. The connection was a bit corroded so i cleaned it up with the ol wire brush. I am using the method that popped up in every search HERE. And when i test cylinders 1&4 (pins 1-2-3) the light flashes for a very short second and then goes out. If i disconnect it and wait about 10 minutes and hook it back up to 1&4 again the light will again just give me 1 quick flash. When i test for cylinders 2&3 (pins 3-5-6) i get nothing. Im assuming the pins go -1-2-3-X-5-6- with pin 4 being missing. Am i doing this right? If so im guessing this thing is dead?
Per luv2rallye,
On a 90 turbo or NT:
Unplug the power transistor 6 pin connector.
To test the power transistor for cylinders 1 & 4:
Connect the negative side of a 1.5V battery to pin 3 (black wire) of the connector. Connect the negative side of a 12V battery also to pin 3. Connect the 12V battery positive to one side of a 12V light bulb. Connect the other side of the 12V light bulb to pin 1 (yellow/green). The light should not be on. Now connect the 1.5V battery positive to pin 2 (yellow). The light should go on.
To test the power transistor for cylinders 2 & 3:
Connect the negative side of a 1.5V battery to pin 3 (black wire) of the connector. Connect the negative side of a 12V battery also to pin 3. Connect the 12V battery positive to one side of a 12V light bulb. Connect the other side of the 12V light bulb to pin 6 (yellow/black). The light should not be on. Now connect the 1.5V battery positive to pin 5 (yellow/red). The light should go on.
Per luv2rallye,
yeah thats the link i used. I test coil pack resistance and it was equal for 1&4 and 2&3
