Swaping in a new engine...
94_eclipse
153
Jan 19, 2007
Shelocta, Pennsylvania
Hey guys, i just found a engine out of a 1992.5. or at least i believe what it is. It has the 2.0 N/T but it has a cyclone intake manifold on it. So i am guessing this is a 6 bolt block. Will this all swap into my car without any problems? My car is a 94 N/T with a 2.0 5-speed. And also this other car is an automatic trans... if that matters. Is there anything that i need? Thanks
If the engine is a 6 bolt you will need to get a 6 bolt nt flywheel. Also, you will have to pull the torque converter alignment cup from the crank to mount the flywheel.
Check the oil pan to see if it is a 6 or 7 bolt motor.
Read post #2. Also the grease method for removing the cup on the crank is a real neat trick. :)
There are some non turbo Eprom ecu's out there. AFAIK the NT cyclone IM did not have the butterflies and dual runners.
The grease trick, pack the end of the crank full of grease and make a packing rod that just fits into the cup. Packing the grease into the crank end with a lot of force forces the alignment piece out.
Grab the cup with a large pair of vise grips than tap the vice grips with a hammer, it should come right out. Had to do that with my 4G64.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
