turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
I know from searching a ton of old posts theres some on on here running high 20's for timing, high 28-30psi boost nd claiming 12.5:1 AFR..they were talking about upgrading both nozzles to i think it was an M17 and M15 for it..
If this is you please speak up, i need to pick your brain a little if you don't mind..post here or PM me.. i'd rather post it all though if you don't mind so others can find it easy in the future. I've only found you in a handfull of threads
thanks for chiming in! Are you having to run that high of nozzles to get an effective amount of meth to keep knock off? I think i hit the limits of an M10 nozzle on stock pump pressure ( no idea what it is though) because i started getting higer EGT's and more knock again so i had to richen it back up to 11.5:1 and back the timing back off from 20 to 16*. I've started a fresh dedicated meth tune.
That really sucks, i was hoping to see it all along the interstate, but no such luck. I was seeing 92 ocvtane as high as 4.35 in some places on the way there. and then once the weekenbd was over on my way back (today) the same places were back down to 3.95 or so for 91 octane..tanlk about a bunch of god damn con artists. People need to start shooting the people who price gasoline
