Guys who used washer reservoir for meth let see some pics
Staytuned
1,587
27
Jan 31, 2004
Kingston, ON, Canada
Anybody have any pics of their 2G washer reservoir with meth fittings and pump placement in their rear hatch? I am starting to install this on my car and curious to see what others have done.
I kept the oem pumps in there so that I can still use my pissers/wipers, if need be. Tapped into the very bottom on the back. You can see where I mounted my pump, and then I also installed a 'check valve', which is under the panel in the back.
That's some expensive washer fluid! LOL
Actually its some cheap meth, LOL.
Quote from Snow Performance:
6. What fluid can I use in my system?
• Boost Juice®: This is the best fluid to use and is Snow Performance's 49% methanol, 51% water mixture that can be shipped to your door or picked up at a local dealer. (If you are using your washer reservoir as the injection tank, Boost Juice® is a great washer fluid – works as a de-icer!)
• Windshield Washer fluid: Only if it is blue in color and rated for -20 deg F. It should have no special additives. This means it is safe to use and made of about 30% methanol, 70% water. If it is another color or another temperature rating, do not use it.
• You can "spike" your Blue -20 Washer fluid to a 50% mixture by adding 3 12OZ yellow bottles of Heet® gas-line-antifreeze to every gallon of washer fluid.
• Mix your own: You just need to make sure the methanol is "neat" and contains no lubricants or other additives. We recommend a 50% mixture.
• Ethanol: It is not as good as methanol, but it can be used as a 2nd best option if you can't find methanol. It can also be mixed with water up to 50%.
• Do NOT use E85 or any other fluid with gasoline mixed in. It will destroy the fluid delivery part of your Boost Cooler® and instantly void the warranty.
• Isopropyl/Denatured Alcohols: These can be used, but are not as good as methanol. They have a lower BTU, or energy content, and a lower latent heat of vaporization (fancy way of saying how much heat they absorb) as well as a lower octane rating compared to methanol.
thats cool the barrels of blue we get at work is 49 51 mix gives me an idea
