ECUflash Stomped on Ecuflash
my dreamt dsm
3,306
34
Jan 29, 2007
Somewhere In, California
The other day I couldn't get the cable to read. Well, I just got my 2.0 cable to read. After it reads the ecu this pops up. I press next but nothing happens.
And Second picture, which ecu do I choose
That message is saying that your retrieving your stock rom from the ecu. You cant view it in ecuflash or edit it. Its just a file of the whole ecu. What i would recommend doing is saving that file and place it on your desktop. The only way you can edit anything is with ceddys rom from his website.
Don't use EvoScan to read/flash. I don't think it's working yet for the 98/99 ECU.
You should be able to download an XML file from the "I can read a 98/99 ECU" (Ceddy's original) thread that will work with your stock rom. You don't need Ceddymods to change simple things. Ceddymods just adds features.
Probably a really really stupid question but after i download the xml format how do I use it or what do I do with it. Just trying to walk before I can run. Thanks Wes!
The link no longer works????
http://www.dsmtuners.com/forums/tun...first-flashed-dsm-ecu-98-99-flashing-faq.html
Edit:
This thread helped a lot. Just wondering if the picture looks right? I'm doing #5 of this thread
http://www.dsmtuners.com/forums/articles-tuning-ecu/407715-how-get-basic-tune-ecuflash.html
On the second picture I'm having trouble with this. I right click it but it there's no options for saving. EDIT; i converted it to xml format... by "saving as"and putting it into ecuflash
Third picture is it suppose to be a hex file or a rom file:banghead:
Now does this look right. Am I missing something?
I'm just doing what was stated in #5 of this page.
And when you're talking about metadata do you mean the rommetadata. I'm really a computer retard.
Why does everyone want to edit there stock Roms?... It's not that hard.
But, why bother? Just save your stock Rom and Flash the newest Ceddy mods.
Oh my f'en god. I did it.
Stupid me...
Open ecuflash, then go to file> open rom> c:/> program files> open ecu> ecuflash> romdata>mitsubishi>eclipse>20550011 xml
Thanks for the help...
RESOLVED!
You're right Wes. It is the BIN and HEX files.
BTW.
Does anybody know what the Antilag Ignition Retard do? I have it set a -3.
Is it the more retard the harder the launch/ higher psi spool?
http://www.linkecu.com/support/documentation/technical-notes/antilag-tech-note.pdf
regular launch control is a 2 step limiter, but antilag retards ign timing with afr control and puts hotter gases into the exhaust that actually may combust in the manifold/exhaust. These hotter gases allow more boost to be built even at lower rpms. (WARNING don't be that retard who gets on the antilag at every red light he stops at (say goodby mr. turbine...))
LOL I have discipline. That's why I'm still in the game with a reliable dsm.
I had ign retard at -5, stationary at 3000rpm, start antilag at 2750. I was just peeling rubber. I have yet to lower it to -3 or even ..
I just want to learn more before messing with it to much. So back to search for me!
