SixBolt_16G
- 1,075
- 1,067
- Nov 7, 2005
Illinois
The same image crossed my mind when I saw his set upYou must be logged in to view this image or video.
I'm taking a moment and going back to my roots of small engines. I picked up a bunch of free lawn mowers (literally four of them). I also got two free pressure washers. All 6 of the engines were running after I tinkered, they all had very old gas and needed the carburetors cleaned. One of the pressure washers had a large crack in the water pump, and one of the mowers had bad piston rings, so it smoked badly and somehow started and ran with 48psi compression. I decided to toss out the pressure washer frame and install the 190cc/8.75ftlbs engine on the mower frame with bad engine. What a dangerous contraption I've made, but it's been performing impressively on the backside of my lot that hasn't been cut in at least a decade. The idle speed is probably twice that of the 148cc/4.75ftlbs Briggs mower engine. I've been mulching small trees and bushes with this death trap. Chaps and safety glasses are a must though. The flying debris out of every side at such a high velocity, it will tear your ass up if you aren't protected. I'm soon to mount a kill switch on the handle bars. The pressure washer was not equipped with a flywheel brake, and leaning down near the high speed blade to hit the killswitch is an interesting task.
The idea was to fix all of this equipment to a functional condition and give them away to anyone locally in need of such things. But this "mower" - or mulcher really - is here to stay. It has already cleared half an acre unbelievably. I really couldn't be held responsible for someone getting hurt by this thing either.
No excuses.I never got around to turbocharging one, but a few years ago I had a pulley swapped TroyBilt Bronco with "microburst" nitrous. It lifted the front wheels a few times before the Kohler plastic cam gear crumbled to bits.
If you're wrapping it anyway, just weld the crack closed. That's what I would do, aside from getting a new header.Found a crack in one of the tubes on the Prelude's header. I put a little copper rtv (700 degree) on to test before getting super involved because I was gonna wrap it but of course it burned off and blew it right out after a short drive the next day...
Anybody a pro at plugging exhaust leaks that can tell me what I can use so that itll last a month or two while i try to track down a better header to replace this crappy DC one? The good prelude headers are all discontinued, even harder to find something decent for an SH model.
Thanks, guess im going to try welding it this weekend.If you're wrapping it anyway, just weld the crack closed. That's what I would do, aside from getting a new header.
That's an H22 car, right? I would look into possibly using an F22 header. I know the F22 headers bolts up to the H23, but not sure if the H22 cylinder head is the same. A lot of this Honda stuff is interchangeable, even if it isn't advertised that way.
