FIBA M - EC17PSE
Supporting Vendor
- 6,752
- 5,159
- Nov 1, 2008
Orlando,
Florida
Hey all im back and I have been trying to read up alot and it seems i been reading wrong as i started again from scratch based from ECMtunings data sheets and details but its not what the car liked and infact made it completely undriveable!!! I was on my way to get my inspection to make it fully road legal but i did not make it due to the bad data on ecmtunings site so im going to ask why they suggest those when its way off and wrong. maybe things need updating from when it was likely put on the site back in 2010 maybe.
so ecmtuning show most FIC injectors had dead times of 330 bar a few, so i decided to use that and sort global out to suit but i could not drive it without it going super lean and sputter!
So I started again from scratch and setup the injectors and adjusted them till LTFT was good, so global is now at -57.8 which is showing injectors as 1055cc??? and deadtime is set to 95 and currently this seems ok and i can drive it but im getting ever so slight lean LC1 reading upon small throttle usage but seems to level out ok but AFest shows at that same time it should be richer by 1 point or so, I seem to have combinedFT decent also but the LTFT and STFT seem to be cycling nicely around the zero mark so i hope im back to where its happier but this is where im stuck as i now do not know the best way to adjust (see below) if the global and DT are ok now it means fine tuning will be for SD i assume.
now currently I have not touch the SD charts as I believe I am understanding them wrongly. I based what i knew from jafros videos but i have been told differently so im here to confirm this also as I dont find any specific details on what the numbers do vs alterations which is kinda shocking since we have some of the best fine detailed threads going on the web!
so from jafros video he states air is fuel and lowering the number means less air and richens it up? but i have been advised that the higher the number the richer it gets. so is someone able to confirm this for me please
here im going to upload 2 logs. one from friday with there 330 deadtime as i read from ecmtunings site and the second is todays which is not alot of driving but it actually is able to drive better without running super lean (18+) from the previous log
small drive is fridays and un drive able and tweaked is sundays and driveable and no way near as lean.
I should note that from my previous posts on tuning i have gotten better cold starts and i am still tweaking them as im almost there now! its about 4 cranks to start and run rather then 8 ish and then trys to start and stalls so another few points on that will help out as its doing ok thus far.
one thing i CANNOT find out still no matter what is air smoothing in the DA section! everyones is different! what do you do to get this right? stock is based on the maf and is about 80 something % away so i did a rough calculation on mine and im about 20 ish % away maybe more like 15% but no matter what i do in this nothing seems to make a difference so why is this here and what do i really do in this part as it must be vital to tell the ecu how fast to react correct?
again sorry for the long essay on this, I want to get out all of what i have done in one message so i dont forget and its all readable in one post to be read over and not hlf the story missing etc
Bobby
Bobby
